Adding a deadline to a task
  1. Select the task to which you want to add a deadline.
  2. Open the Task Information dialog box. Click the Deadline tab.
  3. Enter a maximum duration in the Maximum task duration boxes.
  4. Select the time unit from the drop-down list.
  5. Click on the Task Deadline box. A calendar opens.
  6. Select a date from the calendar.
  7. Select an action that will occur if the task reaches the deadline from the Action for Probabilistic Calculation option box.
  8. Click OK.
Task Deadlines
