Add a Document to a Risk
To add a document to a risk:
- Open the Document tab.
- Click the Add or Link Document button. The
Document Description dialog box opens.
- Type in a document name in the Document Name box.
- Type in a description of the document in the Document Description
box.
- Select either the Add link or Save document in
the database option. There are some considerations you should note in regards to these options:
- If you choose to link a document, this provides a path to the local computer. Therefore, it may not be
valid for other system users.
- If you select Add to database, over time this can potentially impact database size and may
lead to decreased performance.
- Click the Browse button to locate the file.
- Click OK.
About Risk Documents
