Deleting a Project
Deleting a project deletes it from both the hierarchy and the database.
To delete a project:
- In any Project view, select the project that you want to delete.
- Right-click and from the shortcut menu choose Delete. The project will be deleted
from the database.
- You cannot delete the current project. You must close a project before you can delete it.
- You must have appropriate permissions to be able to delete a project.
When you delete project which has risks assigned to this project only you have to choose what to do with these risks. You may:
- Delete all these risks
- Keep risks as hidden (managers and administrators can access them)
- Make these risks visible at enterprise level
Copying and Pasting Project
