Opening ProjectsTo open a project :
You can open summary projects or subprojects as long as you have permissions to do so. However, if you open a summary project, you cannot add a project schedule or resources. You may only manage risks associated with the summary project. If you open a placeholder project, it will not have any tasks or resources associated with it. Once you add at least one task, resource or risk, it will become an active project. Each active project is represented by a Gantt bar in the Portfolio Gantt view. A project can contain qualititative risks. See also |
