Saving a Project
You can add or save an imported project to the database.
To save a project:
- In the Projects view, select the project that you want to save or select
an empty project row.
- In the Projects group, click Save or
Save As. The
Save Project dialog box
opens. The Save Project dialog box allows you to insert the project into your
portfolio hierarchy at any level.
- From the hierarchy, select the position where you want to insert or save
the project. You can rename the project if required in the Project Name
box.
- Click Save.
Creating a Portfolio Hierarchy
