Assigning risks from risk templates to tasks
Interstate
Post by Interstate » Tue Jul 02, 2019 3:46 am
Does loading risks from a risk template into the Risk tab of the Task Information add the risks to the risk register?
Re: Assigning risks from risk templates to tasks
Post by Intaver Support » Tue Jul 02, 2019 3:56 am
If you have not yet imported the risk template into the project, if you load a risk template into a the Risk tab of the Task Information dialog box, the risks will be automatically added to the risk register.
To load a risk template into Task Information > Risk tab, click Load Risk Template.
Note: You can only load the default risk template into a task. The default risk template is set in the Risk Assignments.
Risks with assignments are loaded into the task. Assignments can be enabled or disabled by clicking on the X beside a risk. If you click the Summary assignment, you can disable or enable groups of risk assignments.
You can use Enlarge button to enlarge the list of risk assignments.
