Modifying column widths in the Risk Register
G&G
Post by G&G » Wed Jul 26, 2017 11:43 am
Is it possible to modify the row to present longer text?
Re: Modifying column widths in the Risk Register
Post by Intaver Support » Wed Jul 26, 2017 11:46 am
Yes, there are a few different methods:
1. In the column header, click on the side of the column and hold the mouse key down. The cursor will change to a drag the cursor to modify the column to the desired width.
2. Specify the column width in pixels using the Modify column dialog box. Right-click on the column header and choose Modify Column. In the Width text box enter the width in pixels and click OK.
3. Hover over the side of the column header until it changes as in #1. Now double click and the column width will automatically adjust to fit in the text.
