Maximum task durations affect on the simulation results
Dwen
Post by Dwen » Fri Jan 19, 2018 8:47 am
How does the maximum task duration (see deadline tab) affect the results of Monte Carlo simulations.
Re: Maximum task durations affect on the simulation results
Post by Intaver Support » Fri Jan 19, 2018 8:58 am
It depends on the action that you select if a deadline is met.
No Actions: displays a deadline indicator but will not affect the results of the simulation
End task: ends the task any time the deadline duration is exceeded, so the simulation results will not show any duration greater than the deadline value set.
Cancel task: cancels the task any time the deadline duration is exceeded and sets the duration of the cancelled task to 0. Success rate is calculated based on the % of iterations that do not exceed the deadline duration.
