How is sensitivity calculated?
Fred45
Post by Fred45 » Mon Apr 03, 2017 9:58 am
What is the formula to calculate sensitivity coefficient and what is the threshold for display tasks of risks with very little sensitivity coefficients?
Re: How is sensitivity calculated?
Post by Intaver Support » Mon Apr 03, 2017 10:01 am
RiskyProject uses Spearman rank order correlation coefficient to calculate project parameter’s sensitivity to variance in inputs such as cost or risk events. This formula returns a coefficient that is between -1 and 1. The higher the value the stronger the correlation is between the two variables. Perfect correlation equals 1. Perfect inverse correlation would equal -1.
You can minimize the number of activities or risks in the Sensitivity view by modifying the sensitivity threshold. Any results that have a correlation below the threshold will not be visible. To modify the sensitivity threshold, go to Schedule, Project Options > and modify the value in the Minimum Sensitivity Coefficient box.
