How to create own risk template
Posted: Tue Feb 05, 2008 12:19 pm
by AlanZT
I found risk template interface. I think it is very useful feature. How can I create my own risk template?
Posted: Tue Feb 05, 2008 12:26 pm
Here is what should you do:
1. Define you risk breakdown structure in global risk view
2. Go to Tools->Save Risk Template
3. When you go to Tools->Open Risk Template, you will be able to see the risk template within the list
Please remember that risk templates are saved as a file with extension *.aln. They are located in subdirectory templates of main RiskyProject executable directory. For example in can be c:\Program Files\intaver\RiskyProject 2.1\templates
Posted: Sun Mar 09, 2008 11:23 am
If you have your own risks template and want to share it with our client please send as a note at
sales@intaver.com or
info@intaver.com. You may also post it within this forum With your permission we may include your risks template to the standard set of risk templates, which come with RiskyProject.
Templates
Posted: Wed Apr 28, 2010 10:53 am
by AArthurs
Refernce to the risk libaries topic elsewhere, are templates the same thing as libraries? Where are they located on your site?
AA
Risk templates and libraries
Posted: Wed Apr 28, 2010 2:36 pm
In RiskyProject a risk template provides the same capability as a risk library. If you want to customize a risk template, you can take an existing sample that we have, modify iit to meet your project's particular needs and save it as your own risk template.
You can then load that risk template into your projects. Alternatively, it might be more useful to use risk registers if you do not want to record risk assignments, but would like to maintain the risk property information for each risk.
Risk registers do not keep risk assignments like risk templates, but they can have default values for risk defintion, owner, etc. This may be useful in cases where you would like to maintain the risk properties for risk management.
Can you combine risk templates and risk register
Posted: Thu Jan 20, 2011 8:18 pm
by Hato
The value that I can see with the risk templates is the ability to create a risk hieracrchy that can act somewhat like a risk breakdown structure. I do not see this capability in the risk register. Is there someway currently to do this?
Risk Hierarchy
Posted: Fri Jan 21, 2011 5:10 pm
You cannot currently create a hierarchial view in the risk register. The reason for this is the automatic sorting that occurs in the risk register, which is automatically sorted by Alphabetical order or Risk score once the schedule or project is calculated.
We are looking at creating a different view in the Risk workflow that will allow you to create a hierarchial view for risks, such as found in the Risk Templates.
