Download is interrupted
Jason
Postby Jason » Mon Oct 30, 2017 3:16 pm
Trouble trying to download project risky. The installer keeps getting interrupted and stops.
Jason
Re: Download is interrupted
Postby Intaver Support » Mon Oct 30, 2017 3:20 pm
It is not that your download is being interrupted, the installation is being interrupted. This is normally due to two issues.
.Net 3.5 is not enabled. In Windows 10, .Net 3.5 is installed but not enabled as the default setting. You can enable it in the Turn Windows Features on or off dialog box.
There can also be internal problem in Windows which can cause incompatibility issue with installation of RiskyProject. To check the compatibility, right-click on the install package (e.g RiskyProjectSetup. Msi) and choose
Return to “Project Portfolio Risk Management”
Who is online
Users browsing this forum: No registered users and 1 guest
