Importing Risks from Excel
Brunswick
Post by Brunswick » Thu May 30, 2019 10:22 am
How do I import my risk register from Excel to RiskyProject Enterprise?
Project Manager
Re: Importing Risks from Excel
Post by Intaver Support » Thu May 30, 2019 10:26 am
RiskyProject provides an easy to use mapping process to link Excel spreadsheet data to risk properties in the RiskyProject Risk Register
You can import the complete risk register from Microsoft Excel. To do so, you need to map Excel fields to RiskyProject fields.
1. Add, delete, or modify the default properties in RiskyProject to duplicate the columns in the Excel spreadsheet.
2. Modify the Risk Register view by adding, modifying, or hiding columns so that it replicates the Excel spreadsheet
3. On the File menu, click Import > Risks from Excel.
4. Follow the prompts to open the Excel spreadsheet.
5. Using the supplied mapping dialog, link the risk properties to the Excel spreadsheet columns that they represent.
Post by Tomico » Sun Dec 08, 2019 3:38 pm
Is it possible to import risks to desktop version of RiskyProject professional?
Post by Intaver Support » Sun Dec 08, 2019 3:41 pm
Yes. Importing risks from Excel work the same way in RiskyProject Enterprise and RiskyProject not connected to the database. The only difference the imported risks will be saved in ALM file, not in database.
