Assigning Risks to Tasks with Resource Costs
Looking for some help on how to model risks with resources. I have a task that runs for 3 months, with a resource or resources assigned at 100% for the duration of the task. I have a time delay risk that has a 15% of causing a 10% delay to that task. I want to show an extension of time to that task and then any affecting it in the triangular distribution on the result gantt, but then also an extension of time required from the resource working extra due to the extended time and therefore an increase in cost. How do I go about doing this?
Re: Assigning Risks to Tasks with Resource Costs
If you model a schedule risk with resources allocated to the affected tasks. The added costs due to the increased time due the risk will be calculated based on the resource rate and will be part of the analysis. You can also model this by you apply the risk directly to the resource, however if that resource is assigned to any other tasks, they will be affected as well.
