Permission to delete risks
remerson risk analysis
Post by remerson risk analysis » Mon Jan 18, 2016 11:12 am
We use RiskyProject Enterprise. We need to ensure that we give permission to delete risks only to experienced managers, not to all users. How to do it?
Re: Permission to delete risks
Post by Intaver Support » Mon Jan 18, 2016 11:22 am
RiskyProject Enterprise has extensive user management system which allows to define any permissions for different users and roles. Permissions can be defined by administrator only. To define permissions you need to do to File->Users. You will be presented with the list of users. Then you double click on the user ID and you will be presented with user dialog box:
For each user you can define different permissions, including delete, create, and modify risks, delete, create, and modify risk and response plans, and create projects. Access to the projects defined separately. This dialog would help administrator to customize permissions for each user. The user can always create and modify risks in the project they have an access to. But these risks will belong to this project only. The checkbox Create Risk is only for risk on enterprise level of hierarchy.
