Using with Microsoft Project Server files
I am the admin for Microsoft Project Server and trying to assist an associate with being able to use RiskyProject 6 with Project Server 2010. Does RiskyProject work with MS Project Server and what is required?
Re: Using with Microsoft Project Server files
In the later versions of 6.1 and current version 7, in the Import -> Map Microsoft Project Fields there is an Advanced Mapping button.
You need to set a temporary file location. By default, the software saves a temp file in the same location as the mpp file when using the addin. With Project Server, there is no mpp file, so a location must be set for the temp file.
