Split Tasks
PMBOK
Split Tasks
Post by PMBOK » Tue May 01, 2018 11:05 am
Does RiskyProject supports split tasks as Microsoft Project?
Re: Split Tasks
Post by Intaver Support » Tue May 01, 2018 11:08 am
When you import a split task into RiskyProject from MS Project, the task itself will not be split, but the Start and Finish times will. This means that during the Monte Carlo simulation the finish and start times will be used to model how uncertainties will affect the project; however, if you are using resource loaded schedules, you need to account for the additional work that RiskyProject will add to the “split tasks” because of how they are handled.
Re: Split Tasks
Post by Intaver Support » Tue Nov 12, 2019 11:42 am
In general we don't recommend to use split task for probabilistic calculation, because uncertainties can be related to shifts and non-working time. It is hard to model and can cause confusions. Instead we recommend to use multiple tasks.
