RiskyProject and Primavera integration
How is RiskyProject integrated with Primavera?
Integration with Primavera
RiskyProject is integrated with Primavera software via MPX or Microsoft Project XML file format. If you have a project schedule from Primavera, including Primavera Project Management or SureTrac, you can export it to MPX and XML file. The go to RiskyProject and open this file. You can also export project schedule, created in RiskyProject to MPX file and open it in Primavera software. Moreover if you are using SureTrak, you can launch it directly from RiskyProject’s Tool menu. You will be presented with the project schedule, created in RiskyProject.
Please note, that not all information, defined in Primavera software can be imported to RiskyProject. For example, current version of RiskyProject does not support split tasks. Vice versa, not all information from RiskyProject can be exported to Primavera software. For example MPX file, used to transfer data from RiskyProject to Primavera software does not support risks.
Most of our clients use RiskyProject Professional and RiskyProject Lite with SureTrac. Both applications are easy-to-use and intended mostly for small nd medius size projects.
Re: RiskyProject and Primavera integration
RiskyProject now supports P6 *.xer format which is covered in this post: viewtopic.php?f=3&t=1549&p=3247&hilit=%2A.xer#p3247
