Questions:
1. Is it necessary to populate the Risk Register before doing a quantitative analysis?
2.How do I view/print histograms of the quantitative analysis results? (I\'m using RiskyProject Lite)
Do I need to populate the register?
Project manager
Re: Do I need to populate the register?
Simple answer is no. If you are doing a straight forward SRA using Base, Low and High estimates, you do not need to involve anything from the Risk Register.
The Lite version only provides a very simplified high level reports on the risk analysis (see the 3*3 Report). To generate histograms, cum probability, and tornado reports, you will need to try the Professional version.
Where default risk probability and outcome is comming from? I would like to set default probability equal 20% not 15%.
Project manager
Default probability and outcome is defined in Schedule -> Options -> Risk.
