Pre-mitigation column
RohTR1
Post by RohTR1 »
I found that you have two columns call Pre-Mitigation in Risk Register view. I think one column should be called Pre-Mitigation and the second one should be called Post-Mitigation. I use recent version RiskyProject 5.
Re: Pre-mitigation column
Pre-mitigation column title is a bug in RiskyProject 5. We will fix it in the next release RiskyProject 6 which is comming out later this year.
In recently released version of RiskyProject 5.0.7.1 the names of pre-mitigation and post-mitigations columns are fixed. It is minor release of RiskyProject. It can be downloaded from our web site.
RiskyProject 6 has small issue in labeking for information in risk report. "Pre-mitigation" applies to both "Pre-mitigation" and "Post-mitigation". These labels should be different. This issue will be fixed in new minor release of RiskyProject 6.x.
