Background colors for Schedule Risk Analysis views
RiskAnalyst
Post by RiskAnalyst »
Just updated to version 6. Really like the improvements to the performance of the Monte Carlo simulations, good job! Only beef I have is that that the background colors seem to have been changed. Some shading has been adding to the data columns, I would prefer if it were back to white.
Risk Analyst, PMP, M.Sc.
Re: Background colors for Schedule Risk Analysis views
The formatting (background shading, borders etc.) are set in the Application Look dialog box. It is located in the Tools tab -> Resources and Settings group -> Application Look.
Normally, when you update the new install will pick up the previous settings, but it can also pick up settings (themes, etc) from the Windows settings. To change or customize the look of the software, open the Application Look dialog. It has two tabs: Application Look and Theme. The Application Look allows you to select Microsoft scheme from Windows XP to Office 2010.
In the Themes tab you can further customize grid borders and shading. You may try different combination of color themes.
