Edit Project Calendars
CeRIM
Post by CeRIM »
I am assuming that if you can create a schedule you should be able to edit the project calendar, but I can’t seem to find out where you this.
Re: Edit Project Calendars
RiskyProject is a standalone scheduling software, but we do use common terminology “Working Time”. We do have several standard calendars 40 hr work week, 24 hr. etc. Typically, in RiskyProject, the majority of our users will import the project schedules and including calendars that are defined in the 3rd party scheduling tool. However, if this is not the case, if you creating a new schedule or are going to define a specific calendar for purposes of probabilistic modelling during Monte Carlo schedule risk analysis. You define or edit them in the Working Time dialog box.
You can open the Working Time dialog box from Schedule > Schedule and Calendar and clicking the calendar icon. You can create new or modify existing calendars. Each new calendar can be defined using previously created calendar as a base. To find our more, search on Working Time in our user guides or help system.
