Addin fails to load cannot find resources folder
If you get an error message that the Addin failed to load an OutputDistr.png in a Resources folder this can happen if you have installed the software in a User folders of the system. The standard location is c:/program files/Intaver/RiskyProject xxx/ or any other location, defined during installation process. The resources folder is a virtual folder that is created at runtime and contains files used to generate the addin. In the above case, Microsoft Project will look of the Resource file in the install location, where as the Addin will generate resource folder in Program Files.
To fix this uninstall RiskyProject and reinstall it in the Program Files or any other location, defined during installation process.
