32 vs 64-bit versions of RiskyProject
Is any different in functionality and performance of Win32 vs x64?
Re: 32 vs 64-bit versions of RiskyProject
Whether you should use 32 or 64 bit version of software is dictated by the version of the operating system you have. 64-bit software will not run on 32-bit operating systems, though a 32-bit software will run on a 64-bit system. 64-bit software does provide some performance increases. Higher processing speed, better memory allocation are two, but this is irrelevant if you have a 32 bit Windows OS.
Rule of thumb: Install 32-bit software on a Windows 32-bit OS, install 64-bit software on a Windows 64-bit OS.
We performed a number of test based on real life schedule. Calculation performance of 64 but version is 20-30% faster than 23 bit version.
