Printing Charts
Printing Charts
How can I print a histogram chart?
Re: Printing Charts
There are multiple ways that you can generate print outs off histogram charts.
Method 1: Copy Chart to Clipboard
Right-click on the histogram and choose Copy Chart to Clipboard as either a metafile or a bitmap. This will save the chart as an image to your clipboard and you can then paste it into a document to print.
Method 2. Save to file
Right-click on the histogram and choose Copy Chart to File. You will be prompted to save the file. Remember to select the file format you prefer. We recommend png format as is does not lose quality if you need to change the size. Once you have saved the chart to file, you can insert it into a document for printing.
Method 3: Print the Statistics Report
Once you have run a simulation. Go to Reports > Statistics Report. Select the activity that you want to use to print the histogram. Depending upon how you have the report set up, the histograms (1 per page) for the selected activity will appear in the Report pane. From the File menu, choose Print > Print to print the report with the histograms.
Re: Printing Charts
Charts can be also exported to PowerPoint.
To export a statistics report to PowerPoint
1. Click the Report tab. Click Statistics to PowerPoint. Alternatively you may click on Click File and then click Export -> Microsoft PowerPoint.
2. If Microsoft PowerPoint is installed on your computer, PowerPoint will be launched and the report will be generated using settings defined in Customize Report dialog. Only frequency and cumulative probability charts and tornado (sensitivity) plots are exported to PowerPoint.
