Printing Sensitivity Reports
Is it possible to print report for sensitivity analysis?
Re: Printing Sensitivity Reports
Yes, you can create an ad hoc report from any view in RiskyProject using the Print Feature. Once you have selected the parameters or modified the view (hiding, adding columns etc ), click File > Print Preview to review the report and print the report.
For example if you would like to report the sensitivity of the project Finish Time on task durations, set this up in the Sensitivity Analysis view.
Open the Print Preview pane (File>Print>Print Preview) to preview the report
If you are satisfied with the setup, click Print to generate the report.
