Updates in MSP file are not reflected in RiskyProject
Do you have any insight as to why some files can be read into Risky Project and others can’t? I made a small change to an MSP file (added 20 lines and changed the title) and then RP wouldn’t launch. I could load it through the xml version but these two files never seemed to mesh.
risk manager
Re: Updates in MSP file are not reflected in RiskyProject
if you are switching back and forth from MSP to RiskyProject you should use the button that appears in RiskyProject when you use the Addin.
