Qualitative vs Quantitative Probability and Impacts
Hato
Post by Hato »
How do I enter risk probability and Impacts with and without a schedule?
Project manager
Re: Qualitative vs Quantitative Probability and Impacts
Qualitative: Easiest method is to use the Probabilities and Outcomes tab in the Risk Information view. You can also set up the Risk Register view to enter the data, but this requires adding specific columns to the view.
Quantitative: Once schedule data is added to the file. The interface changes slightly. For example the Probabilities and Outcomes tab, becomes the Assign to tasks or resources, If you are only assigning a risk to one task or resource, this will work. For assigning to multiple activities, the Drag N Drop Risk is preferred. You can also assign risks in the Task Information > risk tab or the Resource Information Risk tab.
