Minimum Requirements for Virtual Machines running RiskyProject.
DavidB
Post by DavidB »
We currently have a Virtual Machines to run our set of project management tools. Could you provide the technical details of the minimum stats necessary for the VR? With that, I can compare with what we have and see if that might be the issue.
David B
Re: Minimum Requirements for Virtual Machines running RiskyProject.
Here are the minimum VM requirements for MC simulations. Like our standard laptop.
As with any computation intensive analysis, more is always better especially if you are running analytics on large schedules.
Virtual Machine Requirements for Azure.
Here are the minimum recommended requirements:
1. CPU: At least 4 vCPUs.
2. Memory: A minimum of 16 GB of RAM.
3. Storage: SSD storage with at least 128 GB to ensure fast read/write speeds and adequate space for temporary files and result.
