Compatibility with SmartSheet schedules
Can schedules created in Smartsheet be imported into RiskyProject Professional?
Re: Compatibility with SmartSheet schedules
Yes, you can import schedules into RiskyProject Professional, but SmartSheet schedules must first be converted into a compatible format. SmartSheets allows you to export your schedule as a
1. Open your SmartSheet project
2. Click File in the top menu
3. Hover over Export
4. Select Export to Microsoft Project (XML)
Once you have the file in a supported format:
1. Open RiskyProject
2. Go to File → Open
3. Select the appropriate file type from the dropdown
4. Choose your converted project file and click OK
