Printing in RiskyProject
I was trying to print results of risk analysis from some data sheet. I was able to print results from most of the data sheets (views). However aparently I could not do it from Project Information View.
Printing from Project Infofrmation view
Ken,
Printing from project information view is not currenly supported. However you can copy any charts to clipboard and save it in you report of presentation. To do it just right click on the chart and then select the option. You can copy chart as bitmap or metafile. You can also save the chart as a JPEG file. Printing from Project Information View will be available in next release.
Re: Printing in RiskyProject
In addition, if you add on primary summary task that includes all of the project, you can include this task in the Statistics Report which will generate all histograms, cumulative probability, and sensitivity to finish time chart.
