Import Calendar from MS Project
I found that calendar I imported from MS Project is different in RiskyProject. The shift supposes to start at 8:30 in MS Project, but after import it starts at 8:00 in RiskyProject. As a result my schedule in RiskyProject it a little bit off.
RiskyProject has a little bit different system to define shifts in the calendar than Microsoft Project. You can define shift started only at the beginning of the hour (8:00 a.m, 9:00 a.m. etc.). If you are bringing calendars with uneven shift times from MS Project to RiskyProject, times in the calendars will be adjusted accordingly. So you may see a slight difference in the project schedule.
The only issue is current version of RiskyProject does not support separate calendar for resources. As a result, schedule in MS Project and RiskyProject may be different, if resources use different calendars. We are planning to introduce calendar for resources in RiskyProject 3.
Re: Import Calendar from MS Project
RiskyProject now supports resource calendars.
