We have just started using Project 2010 and I cannot install the toolbar that I used to have with 2003. Is there a workaround for this or will you have an update to address this?
rgds,
TA
Project 2010
RiskyProject Integration with Project 2010
RiskyProject 3.2 does not support direct integration with Project 2010. You can still import project files using the Import features.
RiskyProject 4 will have a similar integration with Project 2010. It is scheduled for release in late September 2010.
If you use RiskyProject 3.2 and Microsoft Project 2010 use the following procedure:
Importing existing project schedules
Importing Microsoft Project 2010 files
You can import MS Project files using XML format.
1. From the File menu, choose Open. The Open File dialog box opens.
2. Select the format that the project file is in from the Files of type drop-down list.
3. Select the MS Project file format that you just saved.
4. Click OK.
Importing data from other Microsoft Project 2010
1. Choose Open from the File menu.
2. Select the XML project schedule
Due to the specific features of each application and the probabilistic nature of RiskyProject data, in very rare cases there can discrepancies in the original project schedule and imported schedule in RiskyProject.
4. Click OK.
