Monte Carlo summary results
Nathan
Post by Nathan »
When I click on the Gantt bar for the project in RiskyProject Enterprise, I don't see any results in some cases.
Re: Monte Carlo summary results
Project summary dialog in RIskyProject Enterprise supposes to show results of Monte Carlo simulation for the project. The same dialog is used in RiskyProject Addin for Microsoft Project, after you perform Monte Carlo simulations inside Microsoft Project. The dialog shows statistical distributions of project duration for cost, finish time, and duration. It also shows basin project parameters including deterministic and probabilistic duration, cost, and finish time.
If you don't see any probabilistic results in this dialog, most likely it is because your project does not have any results. It is not calculated: Monte Carlo simulations are not run for this project. When you use RiskyProject Enterprise you need to have calculated result before saving the project. Otherwise results will not be saved to the RiskyPoject database. RiskyProject will ask you save results in RiskyProject database because your close a project. You need to say Yes if you want to see the results within this dialog.
