Does the test version allow you see to results (s-curves and other charts)?
I am testing it right now, and when I click on the "results Gantt" on an activity bar, I don't get the s-curves and other results.
Viewing results in the test version
Re: Viewing results in the test version
hank you for your interest in RiskyProject.
The "test" or trial version is fully functional with no differences from the commercial version.
On the Result Gantt
1. Select an activity for which you want to view the results.
2. On the ribbon, click the Analysis tab.
3. In the Task Simulation Results, click Probability Plot.
The Simulation Results window opens.
4. Double-click on a chart to view a detailed graph.
Hope that helps
On the Result Gantt
Hope that helps
