Unsure if low and high have been applied
Ken
Post by Ken »
How can I verify that uncertainty values have been applied to a task?
Re: Unsure if low and high have been applied
To confirm if the uncertainty values have been applied, first apply the uncertaintioes using the dialog.
1. Select the task
2. Open the Set Low/High Duration dialog
3. Enter coefficients and choose a distribution
4. Click OK.
The updated Low and High durations will then appear in the task fields.
Best Practices
• Always validate inputs after applying distributions.
• Check that recalculated values align with expectations.
• Use consistent naming or tagging conventions to flag modified tasks.
• Keep a record of applied assumptions for traceability.
