Global risk check box
Josh
Post by Josh »
How to use "Apply global risks to the task (see Global Risk View)" checkbox within Task Information?
By default all global risks from Global Risk view will be applied to all tasks. If you don't want to apply global risks to the particular task, you can uncheck this box. If the box is unchecked only local risks will be applied to the task.
Re: Global risk check box
The Global Risk view is no longer supported in current versions of RiskyProject. It has been replaced by the Risk Assignment View which presents all risk assignments (local and global) in a combined view.
