Lite and Professional versions on the same computer
Can I install both RiskyProject Lite and RiskyProfessional on the same computer?
Hello CDC,
If you use RiskyProject 1.3 you must uninstall RiskyProject Lite to setup RiskyProject professional and vice verse. If you use RiskyProject 2, you can use RiskyProject Lite and RiskyProject Professional at the same time. However, we don't recommend doing it, because it can cause some confusion.
Yes, RiskyProject Lite and RiskyProject Professional share the same data file. However, some information you define in RiskyProject Professional cannot be viewed or edited in RiskyProject Lite. The example is risk correlations or input for decision analysis.
