Sharing risk register
Post by Tomico »
I have created risk register, abu I want to share it with other people in my team. Can I do it using RiskyProject 4.2?
Re: Sharing risk register
You may use load risk register and save risk register features. To access this feature please click on Risk tab and then click on Risk Register (Export/Import pane). Risk register can be saved in binary file (extension ALR). You may save this file on server to share it within a group. The locking mechanism will prevent multiple users modifying this file at the same time. Please note that risk assignment will not be saved in this file. This file includes only risks with their properties. If you wish to save global risk assignment you may use risk template feature. Risk template is also available within Export/Import pane. RiskyProject comes with few predefined risk templates. If you load Risk template, risk register will also be populated.
