Risk Chart
MichaelTR
Risk Chart
Post by MichaelTR »
When I open the risk chart view all the task bubbles are centered in the middle of the chart.
Is there a reason for this or is this a bug?
Risk chart issue
Obviously the risk chart is a bubble chart, and the most likely reason why they are all centered in the middle is that you are viewing Total Task Cost (vs Total Task Duration). If there are costs associated with the activities the you will see the activites all located on the (0,0) axis. Switch to Task Duration as the metric and the risk chart should display correctly.
Jason
Re: Risk Chart
Post by Jason »
When I print risk (bubble) chart diameter of bubbles does it seem to be too small. The location of circles is correct. Relative diameter of each circle representing cost or duration is also correct. I recommend increasing diameter of circles for printing.
Jason
Re: Risk Chart
Thank you for your suggestion. We will adjust the diameter of the circle in the upcoming release for printing. Please note that may also copy chart to clipboard to paste it to other software, such as PowerPoint.
Fer23
Re: Risk Chart
Post by Fer23 »
In Risk chart I never saw red or yellow circles. When red or yellow circles suppose to appear?
Re: Risk Chart
Most likely you have project schedule with balanced risks: siginificant risks are assigned to task with longer duration or higher cost.
Here is some information about risk chart and how risk chart supposes to look like:
http://www.intaver.com/Help4/RP_Help.ph ... Chart.html
Rtgorwer
Re: Risk Chart
Post by Rtgorwer »
Is possible to print Risk Chart?
Re: Risk Chart
Yes. You can print Risk Chart.
Simply open Risk Chart (Analysis Tab). Click on File -> Print or File -> Print Preview.
