Microsoft Project XML format
What is the Project xml format?
XML is an additional data interchange format.
Microsoft Project 2002 introduces a new data interchange format, XML, which uses the Extensible Markup Language (XML) to represent project information. Complete projects can be exported to XML documents that conform to the Microsoft Project Data Interchange schema. Microsoft Project 2002 can also read (import) XML documents that conform to this schema. Note that the XML files include only semantic project information; view definitions (for example, Gantt Charts or tables) are not included.The MS Project’s Import and Export Wizards allow users to exchange XML data between Microsoft Project 2002, 2003 and custom or third-party applications that support XML but do not use the Microsoft Project Data Interchange schema.
Re: Microsoft Project XML format
Does RiskyProject support UN/CEFACT format?
RiskyProject currently does not support UN/CEFACT XML schema, however we are planning to introduce it in new versions of RiskyProject.
