When you use the RiskyProject toolbar or Addin for Microsoft Project to export a file to RiskyProject, a Go back to Microsoft Project button appears on the top right corner of RiskyProject, which you can use to return to the parent file in Project.
If the button does not appear or disappears if you resize the window, ensure that the file in Micosoft Project is not "read-only". The read-only status will appear after the project name on the MS Project title bar.
Return to Microsoft Project button disappears
