Updating risk history
Can I update the risk history in RiskyProject Enterprise?
Re: Updating risk history
Yes if you have permissions to modify risks. You can only delete records from the history, you cannot add them directly to the risk history. Records are only added to the history when changes are made to the risk assignment or properties.
To delete events from the risk history, open the Risk Register. Select the risk you want to modify and double click to open the Risk Information. Click the History tab. Select the event(s), right-click and select Delete Item.
