Filtering Risks
Filtering Risks
Is it possible to see risks belonging to one category for entire portfolio in RiskyProject Enterprise?
Re: Filtering Risks
In RiskyProject Enterprise if you don't open any particular project, you will see a risk register for entire portfolio. If you open particular project schedule by double clicking on it, you will see a green bar in right upper corner corner indicating the name of the project. In this case if you go to risk register view, you will see a risk register for the opened project. At the center of risk register view you will find a drop down list called "Hierarchy based on":
This box allows you to filter risk register based on category or select all risks for specific category only. If you select "Categories", you will see the hierarchy based on category name. But you can select only one specific category, for example Duration. In this case you will be presented with the list of risks for this specific category. Please note that one risk may affect multiple categories.
