Can I modify the page setup for Gantt Chart
Daniel001
Post by Daniel001 »
Hi, we would like to print out the Result Gantt analysis from the Monte Carlo schedule risk analysis onto a plotter. If I go to the Page Setup it only shows Portrait or Landscape and doesn’t really allow us to format for other sizes of outputs.I find that being able to post the comparison of our current baseline vs the Mean for each task is a great way to start status meeting.
Re: Can I modify the page setup for Gantt Chart
The Result Gantt can be a very useful visual to promote discussion during status meetings. The actual printed output defaults to the system’s default printer. This printer is shown in the File > Print > Page Setup.
You can set the default printer in the Windows Control panel. You will need to select your Plotter as the default printer if you want to do a Print Preview. If not you can select the Plotter as the target printer when you go to the Print dialog. In this case, I would recommend doing a small test, to ensure that the page setup transfers to the larger output.
