Filtering risks
Bergman
Filtering risks
Post by Bergman »
Can I filter risks in risk register based on some parameters, such as sunset time?
Re: Filtering risks
Yes, the risk register comes with a built in filtering capability. Risks can be sorted on any property that exists in the risk register including properties in the Risk Properties dialog as well as any custom properties that you have defined.
The risk register filter is located on the top left of the risk register and allows you to set multiple conditions for the filter using Boolean logic. In the example below we would be looking for risks that could occur prior to June 6 2016 and sunset prior to June 1, 2017 in the Western Division.
