Integration with Asta PowerProject
Rtgorwer
Post by Rtgorwer »
Can I do risk analysis with Asta PowerProject using RiskyProject?
Re: Integration with Asta PowerProject
Yes, in Asta PowerProject you can save your project in Microsoft Project XML format. When you have saved the file, you can then Open RiskyProject and from the File menu, choose Import, Microsoft Project XML.
RiskyProject is largely compatible with Asta PowerProject files, though we do not support links between two tasks that have both SS and FF. In these cases, RiskyProject will ignore one of the links.
