Modifying Project Permissions
How can I adjust project permissions?
Re: Modifying Project Permissions
If you have administrator’s permissions to the User Management module, you can modify project permissions. You will see the Project Name pane on the left, select the project to which you want to provide or modify permissions. On the right is a table of named users in the system. Select the check boxes next to the users you want to grant permission to the selected project. You remove project permissions by clearing the boxes.
