Risk is 100% mitigated
Is there any way to specify that risks which are mitigated 100% by the mitigation plan should not be used in the calculation?
Re: Risk is 100% mitigated
If risks are 100% mitigated, then they are no longer active and can be closed. To close a risk, open the Risk Register, select the risk and double-click on the Risk ID (far left column).
In the Risk Information dialog box > Properties > click the Closed option.
You can also sent probability the risk equals 0. It can be reflected in Risk waterfall chart of Risk Information dialog box: risk probability after mitigation can be equal zero.
