Printing report on format A4
Daniel001
Post by Daniel001 »
Is it possible to print risk register report using format A4? How can I adjust format of my report to be printed or save to PDF?
Re: Printing report on format A4
Yes. You can print risk register report as well as all other report using different format. It is implemented the same way as it is done in any other windows-based software. Particularly to print risk register report:
1. Go to Risk Register view
2. Adjust all columns (width, order, headers) the same way you want to see on printed report
3. Click on File -> Print -> Print
4. Select your Printer property dialog. It is different for different drivers:
5. Select paper size. This Information will be recorder for all reports printed using this driver
