How to assign risks to tasks
Ken
Post by Ken »
I've created a list of global risks. I'd like to assign risks to task and resources. What is the best way to do it?
There two ways, how to assign risks to task and resources.
a. You can defined risks to each task in Task Information Dialog or for each resource in Resource Information Dialog. To do it just double click on task or resource ID. Then go to Risks tab. You can enter risks with their properties in this tab.
b. You can use the Drag N' Drop view which can be opened from the Workflow bar. This view presents your risks in the left pane and tasks or resources in the right pane. To assign risks, select the tasks or resources to which you want to assign the risks. Now drag the risk onto the selected tasks/resources.
c. In the Risk Register, double-click on the risk to open the Risk Information dialog box. Click the Assign to Tasks or Resource tab.
Ken
Risk correlation
Post by Ken »
I found that you have risk correlations. How does it work?
Ken,
Using risk correlation you can define risks which may occur with the selected risk. These risks can be assign to different task in resources. For example, risk "Delay in main component delivery" can occur together with risk "Delay in additional component delivery", because both risk are caused be the same issue with the supplier.
RiskyProject supports only strong positive correlations between risks.
To define risk correlation, go to Risk Information Dialog (double click on Risk ID). Then go to Correlations tab. You can select all risks, which are correlated with the current risk.
We recommend you to try analysis with and without correlation and see the different in overall project duration or cost.
Ken
Post by Ken »
Thank you.
I think risk correlation in the great feature, because we have a lot of risks which are related to each other.
